By quoteslogy
#10466
I think you should follow the instruction in the link
('http://quoteslogy.com/arrow-tv-series-quotes-sayings/', ('Arrow TV Series Quotes') ? 'Arrow TV Series Quotes' : '')
By Angelo
#10478
Hi Smith Bob,
Thanks for the feed back.
This is a very old post. I'll ask someone to move it to the right place. How about try to use this library to handle the wireless communication.make_clickable_callback(MAGIC_URL_FULL, '
', 'https://www.dfrobot.com/index.php?route=DFblog/blog&path=26&id=69&search=dfrobot+wireless', '', ' class="postlink"')
By 3dtechnology2015
#11185
The objective of this project was to control the device with the gamepad, communicating with Xbee. Everything was ok until the program started giving me problems.
My problem is this: What happens to me is that the controller sends me data of the analog button but the Arduino does not receive the same values I send, that is, my goal is to press (J1 or J2) buttons in order to control the speed of the BRUSSHLESS.
engine.
By writersspace
#29605
I also usually check products by wiki.
You mean the joystick value?  or just button value? Have you check the product wiki?
http://www.dfrobot.com/wiki/index.php/W ... U:DFR0182)
Although it is not very good, but it should work. Have you read the analog data?
Are you interested in writing dissertations on different thematic? For example, it can be about IT, Internet resources and new technologies.That is also possible to use this kind of service https://au.edubirdie.com/dissertation-writing-services Your dissertation is not a problem. Write it easy!
By miaturner141
#44451
I have found this interesting article on reading analog data from almost any device. May be this can be of your help. try this out. You alternatively, you can try professional help from eduhelphub
