PROJECTS micro:bit
LED Writing Board (micro:bit Compatible)
DFRobot Apr 03 2018 262309
Parts needed
1 x photo frame
RGB individually addressable LED strip (neo pixels)
1 x microbit
1 x micro:mate(breakout board)
Drawing using neon markers
How it works?
The LED writing board is created using a photo frame that is surrounded with LED strip lights. When button A is pressed, the led strip turns white and flash. When button B is pressed, a random color is generated. To off, press button A and B together.
How to connect?
Micro:mate
RGB LED
Pin 0 Black (Gnd)
GND
Pin 0 Red (3.3V)
+5V
Pin 0 Blue (Signal)
DI
Lay the LED strip around the frame. Try to connect the strip around the entire frame.
As my photo frame base needs to slide in, I formed a U shape.
Program
** You can power around 8 LEDs directly from the micro:bit but, for more than that, you might need to power them separately. I tried just using the Vin of the micro:mate and it seems to work fine. Do take note that if current is not enough, the color may not be correct.
If you want the strip to connect to external supply
** you still need to connect power to the  micro:bit.
This is a bigger version. The concept is the same.
 (This is done by modifying an existing whiteboard). The video is purposely flipped.
Related Blog Post:
Microbit Tutorials
Micro:bit board: an introduction
5 Easy Steps for you to Quick Start with BBC Microbit
Micro:bit JavaScript Blocks Editor: Hello World
Micro:bit JavaScript Blocks Editor: Turning LEDs on and off
Micro:bit JavaScript Blocks Editor: Detecting button click events
Micro:bit JavaScript Blocks Editor: String interpolation
Micro:bit: MicroPython support
Microbit Projects
Mobile Doorbell System with BOSON and Micro:bit
How To Make A Micro:bit Heart Rate Monitor
Microbit Project micro:bit Laser Target
Micro:bit Surprise box
Microbit Project: Micro:bit Selfie Remote
Micro:bit Project: Light(Mood Lamp)
Micro:bit Project: Yes/No Bear
Smart Fan Control System with Micro:bit
LED writing board (micro:bit compatible)
micro:bit car with DFRobot gamepad
OBLOQ-IoT Module +Micro:bit IoT Flower Watering
