PROJECTS micro:bit
Mother’s Day recycled craft using micro:bit,neopixel and laser cutter by Mark Ng
DFRobot May 09 2018 260634
What you need
  • 1. Cardboard from carton box
  • 2. Neopixel strip(6 LEDS) x 2
  • 3. Dupont cables
  • 4. micro:bit
  • 5. Laser cutter
Connections
Neopixel
1. Count the number of LEDS on the strip or ring. Specify which pin the neopixel is connected to.
2. Take note of the arrow direction .
Din is the input (connect to the micro:bit). To connect 8 leds or more (recommended but a lot of
times, I have no problem running 12) in a strip requires an external supply.
Neopixel Micro:bit basic blink
Neopixel Micro:bit basics rainbow
Neopixel Micro:bit basics set individual color
Neopixel Micro:bit basics rotate by 1
** to rotate in the opposite direction, change rotate pixels by -1
Neopixel Micro:bit control by buttons.
Button A blink
Button B random colours
Button A+B off
Download mothersday laser cut files. Feel free to modify the design
Mother’s Day code
Light0 strip will be rainbow color
Light1 strip will change color whenever A is pressed
Press A+B to off
The original content is shared by Mark Ng
Related Blog as follows:
microbit Tutorials
microbit Projects
