$USD
  • EUR€
  • £GBP
  • $USD
TUTORIALS micro:bit
micro:bit JavaScript Blocks Editor: Detecting button click events
DFRobot Nov 23 2017 803
The objective of this post is to explain how to detect when a user presses one of the micro:bit buttons and react to those events, using the JavaScript Code Blocks editor.
The objective of this post is to explain how to detect when a user presses one of the micro:bit buttons and react to those events, using the JavaScript Code Blocks editor. In this simple example, we will toggle some LEDs when the button pressed events are detected.
The code
In order to be able to detect button pressed events, we can use the onButtonPressed function of the input namespace.
This function receives as parameters the button and a handling function that is executed when the click event on that button is detected.
In our board we have two buttons that we can use as user inputs, which are defined as button A and button B. Button A is the one on the left, above pin 0. Button B is the one on the right, above the GND pin.
So, for the first argument of the onButtonPressed function, the buttons are defined in the Button enum. For button A we use Button.A and for button B we use Button.B.
In the case of the second argument, we will specify the handling function as a JavaScript arrow function, which leads to a more compact syntax than when defining a named function.
Note that although we also have functions to check the state of each button (pressed or not) at a given time, we would need to use a technique called polling, which corresponds to periodically check the button of the state.
Although in certain program architectures it is feasible to do it, it is much more efficient to use a callback function (like we are doing) that is triggered when the event occurs, leaving the CPU free to do other tasks when no click event is detected.
Our arrow function will simply toggle a specific LED when it executes. You can check more about LED controlling here. We will toggle the LED at coordinates (0,0) on a click on button A, and the LED at coordinates (4,0) on a click on button B.
You can check below the full source code.
input.onButtonPressed(Button.A, () => {
    led.toggle(0, 0);
input.onButtonPressed(Button.B, () => {
    led.toggle(4, 0);
Testing the code
To test the code, simply click the download button on the bottom left corner and drag the file to the micro:bit driver that should be available on your computer. After the procedure finishes, the code automatically runs and you can test it by clicking the buttons.
As usual, you can also do the tests on the simulation mode. Figure 1 shows both LEDs in the on state in simulation mode, resulting from pressing the buttons.
Figure 1 – LEDs toggled from button clicks, on simulation mode.
He had written many useful tutorials and projects about ESP32, ESP8266, microbit, If you are interested, you could check his blog to know more.
Related Blog Post:
Microbit Tutorials
Micro:bit board: an introduction
5 Easy Steps for you to Quick Start with BBC Microbit
Micro:bit JavaScript Blocks Editor: Hello World
Micro:bit JavaScript Blocks Editor: Turning LEDs on and off
Micro:bit JavaScript Blocks Editor: Detecting button click events
Micro:bit JavaScript Blocks Editor: String interpolation
Micro:bit: MicroPython support
Microbit Projects
Mobile Doorbell System with BOSON and Micro:bit
How To Make A Micro:bit Heart Rate Monitor
Microbit Project micro:bit Laser Target
Micro:bit Surprise box
Microbit Project: Micro:bit Selfie Remote
Micro:bit Project: Light(Mood Lamp)
Micro:bit Project: Yes/No Bear
Smart Fan Control System with Micro:bit
LED writing board (micro:bit compatible)
micro:bit car with DFRobot gamepad
OBLOQ-IoT Module +Micro:bit IoT Flower Watering
REVIEW
